Hello
I download EasyPrint and when i open it says that there is a new version
i press download but the download does not start...
Can somebody help me?
Thanks!
Easy print doesnt upgrade to last version
Re: Easy print doesnt upgrade to last version
I had a similar effect, but the program was finally downloaded.
I showed a lot of patience.
Also check your firewall.
Automatic update to the new version did not take place either. An error has occurred.
But I found the update file in the system. He was in the .../applicacion data/easyprint folder.
Sometimes you need to run the program with admin Permissions
Hello!
I tried to run as administrator and to upgrade but the problem remains.
I also re-instaled the program...
Can somebody give me the instaler for the last version?
Thanks!
Thanks!
You can download it by this post
http://geeetech.com/forum/viewtopic.php?f=48&t=60647
It works!
thanks for this..
Also check out eVidya by Vidya Prakashan Mandir is a One-Stop e-Coaching Platform (Web & App) and an Innovative Student Friendly Companion for Aspirants preparing for various Competitive Examinations like SSC, UPSC, Banking, Defence, etc. Let's Crack Exams, with eVIDYA (App & Web).
