Extruder temperature
Hi, I didn't find any thread about this issue, then I ask for help hier
The printer works well and then, randomly After a few minutes the hotend stops heating. Temperature goes to 0 gradually and Display shows for example EXTRUDER TEMP 200/0, while before was 200/200
I tried 3 times and always have the same Problem. Extruder doesn't work anymore after a few minutes because of the temperature of the hotend.
What could be the problem?
Re: Extruder temperature
Have you tried to check the wiring of Extruder?
Problems started last week, before that was all right.
I checked the wiring :
https://photos.app.goo.gl/SRl5i5kAeOuF34on1
It seems not normal(Normal is 1~6Ω)
[quote=William post_id=82343 time=1517276719 user_id=51382]
[/quote]
Are you saying, that the problem is on the wiring?
If yes, is there a video explaining how to repair/change the cables?
[/quote]
What are you saying?
I have a broken cable? How can I fix it please?
It seems you need a new heating bar
