E180 Problems and fixes so far.
Chuck240
Post by Chuck240 »
Geeetech E180 Experiences so far.
Right off the bat we lost the lcd display. Info online on this problem was maybe the micro SD card on the back side of the display comes loose during shipping. The cure was to release it and re-insert. This didn't help my situation, I had a white screen.
It turned out to be the files on the card were gone or corrupt. I re-formatted the micro SD card. The manufacturer's call them TF cards. I was sent the correct folder with the files and this corrected the white screen problem.
Moving onto Easyprint 3d, this is one buggy program. Crashes, hang ups, and just plain not working. I have the latest version, works ok on one PC and not on another.
I switched to Cura 3.1 and that slicer lets you have a lot of control on you prints.
After messing with a few settings, we are getting really nice detailed prints. The only drawback so far is having to save to a micro SD card and then printing from that card.
The location for the slot couldn't be in a more user unfriendly location.
I picked up a micro SD extension cable to plug in the backside, so I have easier access to inserting the SD card.
I did try saving to g code files and opening them up in Easyprint 3d, so I could transfer directly to the printer. Sometimes it works, other times it crashes in the middle of the print.
I can post my settings I'm using and also the correct files for the LCD screen if anyone wants them.
Good luck!
I some photos on the facebook page, cant upload pics here.
Re: E180 Problems and fixes so far.
I use the Repetier-Host for USB serial port printing, works well.Do you need a copy of my profile?
Deennoo
Post by Deennoo »
William, please can you share your all cura profil or export it ?
Personal Cura profiles for E180 have been uploaded to the forum, you can download
DanThomas
Post by DanThomas »
[quote=William post_id=82099 time=1516190688 user_id=51382]
[/quote]
William, if your rep config is still on offer, may I have a copy please?
TIA
DT
MichaelK
Post by MichaelK »
You can find the settings here: viewforum.php?f=67
Anzoni
Post by Anzoni »
Mi impresora E-180 se reinicia y se va a la esquina (1) y vuelve a comenzar a imprimir, pero ya fuera del lugar en otra posición. Esto comienza haciando un ruido raro como si le faltaran dimensiones al carro de impresion, se va a esa esquina (1). Comenzando a imprimir pero en un lugar diferente al que lo deberia hacer. El fichero gcode, funciona bien en los programas CURA ULTIMAKER 4.0 y REPETIER.
Pero devido a que no encuentro Driver para CURA lo tengo que imprimir con REPETIER.
Cual puede ser el error?.
Post by _kaktus_ »
Hi.
The problem is the constant restart. It would be necessary to find their source.
apak
Post by apak »
try to print with out usb cable pluged in
