Needing Printer Settings for E180 for Cura
howchoo
Post by howchoo »
Hi there,
I'm using a Mac so I can't load the Easyprint 3D software at all (it's Windows only).
I'd like to use Cura as I have in the past, but I need to add the printer manually. Does anyone have a Cura profile or at the very least screenshots of all the printer settings I'll need to set things up? Otherwise, I have absolutely no way to use the printer.
Thanks,
Zach
Re: Needing Printer Settings for E180 for Cura
You can find the cura profiles from the forum
howchoo
Post by howchoo »
Hi William,
I found that thread, but it didn't list all the settings I need. I need the following (see screenshot): https://i.imgur.com/u3iRY8G.png
Specifically, I need these settings:
Printer Settings:
X (Width): ?
Y (Depth): ?
Z (Height): ?
X min: ?
Y min: ?
X max: ?
Y max: ?
Gantry height: ?
Gcode flavor: ?
I'm doing a review guide and video for this printer and so far I'm not even able to print anything :(
Thanks,
Zach
howchoo
Post by howchoo »
Ah, I found them! Different post, thanks
