Repetier Host print preview not in sync
Linnearuk
Post by Linnearuk »
I've just built a i3 Pro B and everything seems operational
All motors move in correct directions
All endstops work
Homing all axes sends them home
BUT
When I load a project into Repetier despite centring it using the centre button and it appearing to be in the centre of the field it starts printing at Y = 0 and it appears to be trying to print correctly but I lose half the print because the endstop stops it moving further back (as it should)
Any ideas how I fix this lack of synchronisation between the print preview and the printer?
(The X and Z axis appear to be perfectly fine)
Gingko
Re: Repetier Host print preview not in sync
Post by Gingko »
Have you checked the voltage of A4988 of Y axis? Maybe it's a little low, up to 1.0V to have a try.
if no help, swap the A4988 and reburn the firmware.
and you can test the .gco file from attachment.
PROB TEST.rar
(23.47 KiB) Downloaded 1835 times
Linnearuk
Post by Linnearuk »
Tried playing with bed front and setting endstop to Y max last night but to no avail so I'll try this.
Many thanks
Linnearuk
Post by Linnearuk »
The prob test print almost worked but as the y axis tries to live back toward the origin it "judders"
(no issues forward)
Complete novice here but could it be a belt tension issue?
(I don't have a meter to test amps, volts etc., sorry)
Gingko
Post by Gingko »
Yes, you can check the tightness of Y-axis, loosen it a little to have a try
or swap the driver(A4988) and see if the Y-axis can move normally or not.
kittydurgans
Post by kittydurgans »
slope unblockedIt was very useful to me. Thank you so much as you have been willing to share information with us. We will forever admire all you have done here.cookie clicker
vivekrathod
Post by vivekrathod »
Don't miss the best wireless earphones under 2000 in India with all the facilities and great quality, super deal. best wireless earphones under 2000
