Helps set up for ABS.
Re: Helps set up for ABS.
Would you like to describe in more detail what you can't do with?
Hi, I was using these settings with the 1.0.4 Firmware.
But first, I want to establish a caveat for this settings... I live in Paraguay, and we have almost all the time a very high humidity in the ambient, so I tend to heat the bed much more that the recommended settings to avoid warping of the prints with the glass bed.
Firmware: Marlin 1.0.4 modified and compiled by Geeetech. Uploaded bya EasyPrint 1.1.7
Software: Cura 3.3.1
S.O.: Windows 10
Filaments:
I will update mi settings if I can print nicely again with that version.
Regards and good luck!
S.O.: Windows 10
Filaments:
- Fabricant: Hatchbox
- PLA
- Extruder: 200° C
- Bed: 80° C
- Print speed: 50 mm/s
- Travel speed: 100 mm/s
- ABS
- Extruder: 230° C
- Bed: 114° C
- PLA
Printer: Geeetech Prusa I3 Pro W
Firmware: Marlin 1.1.8 with BLTouch
Thank.neowinx wrote: Fri Jun 29, 2018 8:35 am Hi, I was using these settings with the 1.0.4 Firmware.
S.O.: Windows 10
Filaments:I was using these settings with the original firmware that comes with the printer (1.0.4 as establised above). Now, I have updated recently to the 1.1.8 Marlin firmware but I am still struggling to print with the same quality as before because the movements calculations of the nozzle in Marlin versions between 1.0.x and 1.1.x are very different. Mi nozzle now moves so fast that it seems it is running a race or something.
- PLA
- Extruder: 200° C
- Bed: 80° C
- ABS
- Extruder: 230° C
- Bed: 114° C
I will try to do as you suggest.
