I'm not sure if that's my issue or not but it seems like it's not getting close enough to start first layer.
Here I have the gcode I'm trying and a video of what it's doing.
https://drive.google.com/open?id=1Wf1u4 ... TRewYaX1Y9
Any help would be appreciated.
Extruder doesn't get close enough to bed?
Anunnymous
Re: Extruder doesn't get close enough to bed?
Fixed.
Solution: Read the firmware instructions.
"Note:
Check the threaded rod of your printer(Especially I3 PRO X, I3 PRO W, I3 PRO B, I3 PRO C)
If your printer working with T8 threaded rod
You need to send Gcode"M92 Z400" via USB port.(When you upload the firmware finished)
Then you need to send Gcode"M500" to save the setting."
"Note:
Correct!
Glad that you find it!
