Problemi stampa / printing problem
I Bought my prusa i3 pro w , and successfully assembled, but i have a problem when i try to print something. It wont print the project i send to printer with my laptop. It only print a vertical column in a very bad mood. I try everything and it wont change anything. Have i need to set something on my printer ? I see there are controls in the lcd menu with movements and other stuff. I need help to solve the problem. Thanks for reply.
comecocos5
Re: Problemi stampa / printing problem
Check that stepper motors are properly connected.
In the printer go to configuration, prepare, move axes, select a speed (the Z axis only works with 0.1mm / s or 1mm / s) and then select an axis for move. There you can see if an engine moves or not. If they move, it will be a problem of the gcode file that you want to print, if it does not move it is that there is a problem with the connections, motors or the control board
