I have set up the temperatures to 185°C for PLA and 70°C for bed, but whenever I start a print PLA temp jumps to 200°C and bed temp goes down to 60°C.
My exact temperature settings in Cura are as follows:
Print Setup:
- Default Printing Temperature: 185°C
- Printing Temperature: 185°C
- Printing Temperature Initial Layer: 185°C
- Initial Printing Temperature: 175°C
- Final Printing Temperature: 170°C
- Default Build Plate Temperature: 70°C
- Build Plate Temperature: 70°C
- Build Plate Temperature Initial Layer: 70°C
Material:
- Standby Temperature: 175°C
How do I fix that? Am I missing another setting?
A10 won't keep temp settings
Re: A10 won't keep temp settings
Hello.
You've probably forgotten about the additional configuration in the slicer, or the printer itself.
Have a look again everywhere.
Also check if your startup scripts do not have a static entry of temperature settings.
In 'Manage Printers' / Machine Settings take a look at the Start G-Code
I BET that the two lines
are in there and either commenting them out with a semi colon
or deleting them entirely will fix this.
Code: Select all
c
M190 S60;Heating bed
Code: Select all
;M109 S200;Heating nozzle
;M190 S60;Heating bedRe: A10 won't keep temp settings
That's it! I added a semicolon at the beginning of both lines and now my temp settings are used. Thanks!
Thanks, this was the answer I was looking for too
thanks, that was driving me bonkers.
SeniorUrchin
I have the same issue with the machine overriding Cura temperature settings. I checked the starting code and there is no such line. Changing the settings in firmware seems to do nothing.
I have another issue with printing single colors. Cura slices my models and they look fine, but they print a blend instead of different colors. If I try to print a single color file I get the blend, even if I disable the unused extruder.
