Nozzle sizes on A10M
Akuma
Post by Akuma »
I have bought this machine and just found that the nozzle size is not standard and only comes in 0.4mm for this hot end. Just wondering if anyone knows if a Crealty nozzle will work? I'm looking to use larger nozzles than 0.4mm and would hate to think that this printer is limited to 0.4mm.
Fugly
Re: Nozzle sizes on A10M
Post by Fugly »
what i know (don't own mine yet its on its way) is that it only works with a 0.4.
Gingko
Post by Gingko »
@Akuma, sorry, the thread for A10 nozzle is M6, but the thread for A10M nozzle is M7.
vert wrote: Wed Nov 28, 2018 2:43 am
Gingko wrote: Mon Nov 26, 2018 9:43 am @Akuma, sorry, the thread for A10 nozzle is M6, but the thread for A10M nozzle is M7.
wonder if it might be less confusing if the a10 and the a10m had separate forum sections.
We will add this to the FAQ then others can check it!Cheers
Akuma
Post by Akuma »
Thanks Guys.
So the A10M has a 1mm larger thread? So all I have to do is find a M7 nozzle?
Akuma
Post by Akuma »
I think there is confusion with the labelling of the nozzles. The M7 thread size seems to be an MK10 nozzle. An M6 thread is an MK8. It's not a great system that has been chosen and I'm still not 100% sure, which is why I'm holding off spending £12 on a pack of MK10 nozzles until someone can tell me that this is correct.
APLEES
Post by APLEES »
The A10M has a 7mm Thread nozzel, you should have got a spare in your kit to measure.... I did...
Akuma
Post by Akuma »
I did, but I is it isn't all about the thread size. They might have a different rake angle and overall length. Is MK10 compatible?
Pls check the FAQ of the A10 series printer
Akuma
Post by Akuma »
Yes, I found the other day thanks
