A10M Mixing color
robbyrossi
A10M Mixing color
Post by robbyrossi »
Hello community,
I have bought a Geetech A10M but in "easy print" I not found a way to print with mixing color/dual extruding and not found A10M printer (also firmware upgrade).
There are a guide to print with mixing color with easy print and see A10M printer?
Please help me
Thanks in advance
Regards
Akuma
Re: A10M Mixing color
Post by Akuma »
Sorry I don't know what "easy print" is. I would try going on YouTube. There are plenty of videos showing how to dual colour print with it. That's how I learned
Post by _kaktus_ »
Hello.
This is a software of the GT brand, functionally similar to Repetier-Host and the like. ;)
When you issue a T1 or T0 command while printing, the active extruder is switched.
In addition, check that your model has a function in the control panel that allows you to mix and / or switch the active extruder.
Adding commands I was talking about directly in the prepared Gcode script will switch extruder support. When you load two colors of filament into extruders, you will receive a two-color (or more) printout.
:D
