initial test goes apparently well. probe gets stowed/deployed couple of times, light stays steady lit red.
M280 P0 S120 test is working well too.
M280 P0 S90 retracts probe as expected. the light lits red as well.
M280 P0 S10 extends the probe as expected. light turns off (no blue light, thats normal for 3dtouch right?)
at this point M119 reports:
Code: Select all
Send: M119
Recv: Reporting endstop status
Recv: x_min: open
Recv: y_min: open
Recv: z_min: open
Recv: ok
if, however, i keep finger in touching distance, the probe drops down, can't fully extend (by one-two mm at most) and goes into blinking mode. M119 reports as follows:
Code: Select all
Send: M119
Recv: x_min: open
Recv: y_min: open
Recv: z_min: TRIGGERED
Recv: okduring actual z-axis homing what happens is, as soon as extended probe touches the plate it retracts, then immediately drops down, all while moving downward, on second attempt (presumably) the firmware detects something fishy and stops the printer. depending how low 3dtouch is mounted it may or may not result in a hit of the nozzle against print plate.
i hope this is enough info for someone to help me diagnose the issue here.
thanks in advance!
