Need to look at replacing a faulty x-axis end stop switch. It's attached to a module that is in turn attached inside the housing for the motor, the one with the big QR code.
I tried the 4 bolts on the motor, as it looks like they go into the housing on the other side, but man those are tight bolts and I don't want to strip them...am I headed in the right direction?
Access to the x-Axis end stop module
Re: Access to the x-Axis end stop module
Yes you are. Be careful and hold the motor with one hand because those screw keep it in place.
bunnysando
I wasn't going to back them all the way out, but let me ask you this...Are these bolts lefty loosey, righty tighty? I have already run into some that are not and these are tight, I just don't want to strip anything.
thanks for confirmation
Unscrew = counterclockwise
Screw = clockwise
Screw = clockwise
bunnysando
very good to know...I hadn't attempted this until I had my hands on some better tools...possibly saved me a ton of trouble.
