When I start to print a 3d model, the first layers is done well, but the second one is printed a little bit more to the right and so. So I end up with a useless object.
     I thought that the belt might be a little loose, but thats not the case.
If anyone can help me that would be perfect! Thanks
						Gradual movement to the right of the x-axis while printing
				alfrecanto11
Re: Gradual movement to the right of the x-axis while printing
It seems we can't get more details of it.
1.The print speed(The travel speed)
2.The vref of the a4988(X axis)
Try to set it to 0.8V~1.2v
3.You can use the toolkit to tight the belt
