Power supply Fan not working
liose
Post by liose »
Hello
I just recived my A10 Today and everthing is working fine exept the power supply fan. During the complete heating process it was never began to spin. So i decided to Interrupt the process. Is this a normal behavior or should the fan spin all the time ?
Thanks in advance
Re: Power supply Fan not working
Post by _kaktus_ »
Hello.
A few days ago, the same question was asked in this forum :!:
Most likely, your power supply has intelligent fan controls.
The fan should only switch on when the inside of the power supply becomes hot.
You can test it.
Majix
Post by Majix »
_kaktus_ wrote: Sat Nov 24, 2018 10:15 pm Hello.
You can test it.
Exactly how do you test it?
Post by _kaktus_ »
Hi.
The easiest way to do this is to use a hair dryer with the hot air on.
It's a good idea to find out where the heat-sensitive element is located and heat it directly.
