Nylon 3D Printer Filament
				leongy1717
Can A10M model print Nylon filament at 260 - 280 (normally 230 - 270)? Please advise. Thanks in advance
						Re: Nylon 3D Printer Filament
Hi, I am afraid not, A10M high-temperature  PTFE tube temperature is 260 °.
				leongy1717
Found specially-made Gizmo Dorks Nylon 3D Printer Filament 1.75mm of reduced Printing temperature : 230 - 260°C.William wrote: Thu Jun 13, 2019 5:10 pm Hi, I am afraid not, A10M high-temperature PTFE tube temperature is 260 °.
Recommended Heated bed of 110 - 145°C helps combat Nylon's warp.
So advisable to program A10M to 258°C max, would this work?
If suitable, then will avoid other Nylon OEM brands with Recommended Nozzle Temperature: 250°C- 280°C
