Geeetech A10 X axis problem..
N0mNus
Post by N0mNus »
Hello.. I had bought an A10 a few days ago .. and car home or leveling .. X axis not set properly .. how can that be?
Video: https://youtu.be/Z9gcw6zUvDM
Thanks for Help..
translate with google. :|
Re: Geeetech A10 X axis problem..
Hi, you can refer to this:viewtopic.php?f=17&t=60927
to test the X-axis endstop work normal.
N0mNus
Post by N0mNus »
endstop tested
Reporting endstop status
x_min: TRIGGERED
y_min: TRIGGERED
z_min: TRIGGERED
Hi,I think you need to check the end stop wiring problem.
N0mNus
Post by N0mNus »
endstops go .. he does not drive right in the middle ... that's my problem .. made a new video
https://youtu.be/SwzXrG1XgBg
echo:SD card ok
SENDING:G0 X100.0 Y100.0 F3000
echo:busy: processing
SENDING:M84
>>> M119
SENDING:M119
x_min: open
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
Log Connect:
Connecting...
start
Printer is now online.
echo: External Reset
Marlin 1.1.8
echo: Last Updated: 2017-12-25 12:00 | Author: (none, default config)
echo:Compiled: Jun 14 2019
echo: Free Memory: 3173 PlannerBufferBytes: 1232
echo:V11 stored settings retrieved (614 bytes; crc 17710)
echo:poweroff stored settings retrieved (44 bytes; crc 0)
read file dir:
read file name:
echo: G21 ; Units in mm
echo: M149 C ; Units in Celsius
echo:Filament settings: Disabled
echo: M200 D1.75
echo: M200 D0
echo:Steps per unit:
echo: M92 X80.30 Y80.80 Z400.00 E93.00
echo:Maximum feedrates (units/s):
echo: M203 X400.00 Y400.00 Z400.00 E45.00
echo:Maximum Acceleration (units/s2):
echo: M201 X5000 Y5000 Z50 E5000
echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
echo: M204 P1000.00 R2000.00 T1000.00
echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_us> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
echo:Material heatup parameters:
echo: M145 S0 H190 B60 F0
echo: M145 S1 H240 B90 F0
echo:PID settings:
echo: M301 P226.93 I0.43 D854.89
echo: M304 P182.46 I35.92 D231.70
hardware version:2.20echo:Fixed parameter (6 bytes; crc 54301)
echo:SD card ok
N0mNus
Post by N0mNus »
okay .. firmware fix or settings?
Thank you very much
