Sanguinololu 1.3a Head bed
Kdixon78
Re: Sanguinololu 1.3a Head bed
Post by Kdixon78 »
All motors are working fine now there was a problem with the plug.
The heat bed still can not be hooked up as it results in instant smell of impending fire. The wires are not touching anywhere.
zhangxueyou
Post by zhangxueyou »
Did you plug the stepper driver in the opposite direction?
Kdixon78
Post by Kdixon78 »
Not sure what that has to do with the heat bed but no, I did not install anything backwards. The stepper drivers came pre installed from you guys. The power plug for the extruder motor wasnt seated properly. Right now all I can do is print on blue tape with no heat bed.
zhangxueyou
Kdixon78 wrote:Not sure what that has to do with the heat bed but no, I did not install anything backwards. The stepper drivers came pre installed from you guys. The power plug for the extruder motor wasnt seated properly. Right now all I can do is print on blue tape with no heat bed.
What is the type of heat bed and what is the resistance of heat bed?
Could you please take a picture of mainboard and heat bed?
Kdixon78
Post by Kdixon78 »
The heatbed is the MK2 A bed, the printer is the i3 pro B.
How do I go about testing the resistance of the bed?
Also what should the voltage be coming from the power supply?
At this time its printing perfectly again, just can't hook the heatbed wires up or its instant poof of smoke.
zhangxueyou
Kdixon78 wrote:The heatbed is the MK2 A bed, the printer is the i3 pro B.
Unplug the heating wires from mainboard, unplug hotbed thermistor, use a multimeter to test the resistance between the 2 ends of thicker wires.
Kdixon78
Post by Kdixon78 »
.7 ohms
zhangxueyou
Kdixon78 wrote:.7 ohms
The hot bed seems not so good. 0.7ohm will almost double the current, and the MOSFET will be burnt.
You should contact the customer service. Tell them your problem.
4x6hp
Post by 4x6hp »
I have a same simptoms with smoke. Tested the resistance of the bed and get 1.0 ohm. Is this ok? This is a new Geeetech Pursa i3, just got before few days from eBay.
Also, I have:
1. LCD issue with garabage characters.
2. Extruder bracket P4 part bend down.
3. After issue with the smoke bed MOSFET, it seems that Sanguinololu bed MOSFET is burn out.
On Sanguinololu, all of axies is moving, extruder filament motor is moving and the heating of the extruder is ok.
Filament type used is ABS with default values of temperature.
Hot bed temp was rised to quick, less than 1 minute up to 90 degrees.
Please note, this is just assambled new printer. Less then 2 hours of working.
zhangxueyou
Also, I have:
How do you mount the mainboard to acrylic plate?
