Slic3r two-color printing with Geeetech i3 pro C
gpau
Re: Slic3r two-color printing with Geeetech i3 pro C
Post by gpau »
Tried even so, nothing changes
Enclosed is my configuration of Slice3r
Setup Slic3r.zip
(3.2 MiB) Downloaded 606 times
bang
Post by bang »
I guess you can try my .gcode file to take a look?
two_color_cube_1 +1.zip
(30.49 KiB) Downloaded 528 times
gpau
Post by gpau »
I'm trying every possib solutions can not stamare the two colors.
I checked all the configurations and tried the attached file but not riescoa print, printing always comes out well.
In the firmware you have to change the setting, if you have to put that ettings? Now is it so
Code: Select all
  // these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
  // X and Y offsets must be integers
  #define X_PROBE_OFFSET_FROM_EXTRUDER -25
  #define Y_PROBE_OFFSET_FROM_EXTRUDER -29
  #define Z_PROBE_OFFSET_FROM_EXTRUDER -12.35
In slicer I have to put these parameters?
cosmith
Post by cosmith »
No. Those are for an auto-leveling sensor like the 3D Touch.
gpau
Post by gpau »
Ok, what I am to be changed?
cosmith
Post by cosmith »
Code: Select all
#define HOTEND_OFFSET_X {0.0, 32.00} // (in mm) for each extruder, offset of the hotend on the X axis
  #define HOTEND_OFFSET_Y {0.0, 0.40}  // (in mm) for each extruder, offset of the hotend on the Y axis
gpau
Post by gpau »
OK,
Tkanks so much
