Page 3 of 3
Re: Sanguinololu Rev 1.3a, MINTEMP on boot
Posted: Thu May 21, 2015 10:53 am
by XYZM
I do not have a LCD...I started a new thread with my problem..I think it should be continued there because I do not have the sanguinololu
Posted: Thu May 21, 2015 2:37 pm
by zhangxueyou
Normally, the resistance of thermistor could not be 80 ohm when temperature is 25°C.
Posted: Thu May 21, 2015 8:58 pm
by XYZM
its about 30 Degrees Celsius here in Florida :?
But I found a solution to my problem..
Since I have only one extruder, the software thinks I have two, even if I adjust the printer settings to one extruder..
So to test something I decided to plug in my heatbed thermistors into extruder 2, while having my only extruder plugged into extruder 1 thermistor.
Doing this the computer thinks I have two extruder because it gives me a temp reading for two extruders..I no longer get mintemp error.
So what do I need to change to make the software only use one extruder??
The firmware you have emailed me?
Posted: Fri May 22, 2015 9:16 am
by zhangxueyou
The firmware I sent you can both work for single extruder and dual extruder.
If you use default setting in Repetier , it will print with one extruder, you don't need to set anything.
