Heat Bed and LCD Issues
tuncangin
Re: Heat Bed and LCD Issues
Post by tuncangin »
Yeap. I hope
Xadamx1
Post by Xadamx1 »
I tried, it to the point where there weren't any nuts or bolts on it at all, no luck. Thanks for the suggestion though!
Xadamx1
Post by Xadamx1 »
Just replaced the Ramps 1.4 board, and that fixed every problem I had.
midiman310
Post by midiman310 »
Xadamx1 wrote:Just replaced the Ramps 1.4 board, and that fixed every problem I had.
I just opened up a brand new Geeetech RAMPS board the LCD2004 display had random characters on the screen also. Moved it back to my Acryllic I3 and LCD was fine. I have the RAMPS mounted to an old "Italian" Arduino MEGA2560 I had from my LED light show left over. Went to trace the problem. Ohm'd out all the LCD input linews and the lines ohm'd out fine. Re-tried, still random characters on the screen. Decided to re-flow all the input pins that come from the MEGA to the LCD Adapter card on the RAMPS board. Here are the pins listed in the picture diagram.
After re-flow the LCD display now works perfectly:
Using the LCD for my scratch built Rostock printer with motors/bearings/most electronics using Geeetech parts.
