Reprap Hot End V2.0 resistor
BenP
Post by BenP »
Greetings Geeetech.
Can you tell me what resistor is used on the Reprap Hot End V2.0. And do you sell replacement resistors for that hot end??
I would also like to buy different size tips for that hot end.
Thank You.
Ben
The Future Is Open Source!
Alex-w
Re: Reprap Hot End V2.0 resistor
Post by Alex-w »
hi ben
1.the Thermistor is DHTAB104-952
THE heat is 12v 35w(length 15mm Φ6)
2.the Thermistor:http://www.geeetech.com/heat-resistor-47-ohm-p-786.html
THE heat:http://www.geeetech.com/12v-30w-cartrid ... p-804.html
i hope these would help you
Elmar88
Post by Elmar88 »
Hey,
I was trying to use the marlin firmware and choose the thermistor of the hotend reprap v2.0 buda style. However the thermistor you mention here doesn't seem to be in the list provided. Would you by anychance know which one i should choose?
Also i am wondering the same for the thermistor for the heatbed which is according the the package list a 100k NTC thermistor, should I use option 1 for this? Thanks in advance
Here is the list:
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is Mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 11 is 100k beta 3950 1% thermistor (4.7k pullup)
// 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
// 20 is the PT100 circuit found in the Ultimainboard V2.x
// 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
// 1047 is Pt1000 with 4k7 pullup
// 1010 is Pt1000 with 1k pullup (non standard)
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
// 70 is 500C thermistor for Pico hot end
#define TEMP_SENSOR_0 -1
#define TEMP_SENSOR_1 -1
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 0
Alex-w
Post by Alex-w »
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_BED 1
adneycandy
Post by adneycandy »
very nice
