FriendlyArm mini2440 with LCD P35+ Windows CE does not start
piotrek_em
Post by piotrek_em »
Dear Friend,
In October we bought 20 pieces MINI2440.And the Windows CE doesn't start . I use nboot_P35.bin, superboot2440.bin and NK_P35.bin that you sent to me recently. In MINI2440 which I ordered in May, everything is alright. I checked everything in the Minitools. LCD P35 is the same (I connected the display to the older MINI2440), computer is the same (S3C2440 400MHz / 64MB / 1GB(SLC) ID:ECD35195). Linux is loaded correctly, I checked it. It differs only bootloader in NOR (old works well - Superboot-2440 V1.1(20130529) by FriendlyARM) new works badly (Superboot-2440 V1.3a(20131213) by FriendlyARM) - Linux loads correctly, Windows incorrectly.
I checked upload to the bootloader in NAND both nboot.bin and superboot2440.bin.
Please reply how upload to new MINI2440 Windows CE 6.0. I think the bootloader superboot have been changed and Windows don't start.
Please kindly help me to solve the problems. I need MINI2440 witz Windows CE.
And I have some questions.
1. Do you have a Windows CE 6.0 version of the Russian?
2. Do you have a simple instruction how to prepare own Windows CE for FriendlyARM MINI2440?
3. Required tools (VS??, a Builder?...) to prepare own Windows CE?
4. Please send ( or give the link) files to compile Windows for mini2440 with LCD display P35 (on the cd do not have these files).
Best Regards
Piotrek_em
john
Re: FriendlyArm mini2440 with LCD P35+ Windows CE does not s
Post by john »
Piotrek_em,
Here is the link of the newest CD,I think you can find out the files you want in it.
Please search the detail in the CD.
http://pan.baidu.com/s/1kT84N2Z
piotrek_em
Hi John,
I have the newest CD and files on CD - the bootloader nboot_P35.bin and nk_P35.bin are correct for MINI 2440 with Superboot-2440 V1.1(20130529) in NOR.
But these files isn't correct for the new Superboot-2440 V1.3a(20131213) in NOR.
I checked this
Please help me solve my problem.
piotrek_em
I will add that the new MINI 2440 are with Superboot-2440 V1.3a(20131213) in NOR.
If there is no solution to this, please detailed instructions on how to change the bootloader to older using new J-Tag. (J-Tag has also change - Manual on CD about J-Tag is invalid ).
john
Post by john »
Hi Piotrek_em,
Sorry to reply you late. I had asked our supplier FriendlyARM (We are just the agent of FriendlyARM ) about your questions, but they gave me website address where most of their cumsumers exchange ideas, I think you can find out the answers there.
Here is the website address: http://www.arm9home.net/
You can register an ID.
If necessary, contact with them directly.
John
piotrek_em
Hi John,
Please give me the e-mail technical contact to someone. I still don't have the solution. And the forum http://www.arm9home.net/ is only in Chinese. I need contact speak English.
I using j-tag changed the bootloader in NOR to old superboot and its doesn-t change. I think we must be prepared to compile a new Windows. What has changed since May hardware MINI2440?
I have have superboot, and NK.bin wich works with MINI2440 + P35 ( which were bought in May). Mini2440 with new orders do not work with NK.bin (prepare for P35).
Piotrek_em
