STL file for Geeetech prusa 3
carmelo42
Post by carmelo42 »
I have just finished my Geeetech Prusa I3, and it's working fine ! :)
But I want to print the 4 plastic parts of the printer (the 2 for Z axes and the 2 for the extruder).
Please provide this pieces files so I'll be able to print them in case of break (one is a little broken already)
My mail : carmelo42 AT gmail DOT com
Carmelo
thegman
Re: STL file for Geeetech prusa 3
Post by thegman »
I have the same printer and would also like to receive all the STL files to print as a backup.
I also have an issue with one of the pieces I got being cracked.
Thanks.
Admin
Post by Admin »
STL files are in the zip file.
Acrylic_I3_STL.zip
(539.03 KiB) Downloaded 663 times
thegman
Post by thegman »
Thanks, what setting do you recommend these get printed at?
material, layer height, % fill, type of fill, etc.
Can you send a slic3r configuration? That may be easier.
Admin
Post by Admin »
It depends on what material you use. ABS or PLA or else?
thegman
Post by thegman »
Which would be better to use? What do you guys use? I would use the same material with the same slic3r configuration.
Admin
Post by Admin »
Mainly, they are different in temperature setting.
