Page 1 of 2
Print quality issue
Posted: Wed Apr 08, 2015 9:27 pm
by vad7
Printer is Acrylic Prusia I3.
ABS plastic.
Default setting in RepetierGEEEtech 0_90D_2, .2mm, 19x15, ABS 1.75mm.
Printed at 260-265C, bed - 110C.
- 1
- 1.jpg (98.97 KiB) Viewed 13053 times
- 2
- 2.jpg (99.99 KiB) Viewed 13053 times
- 3
- 3.jpg (70.81 KiB) Viewed 13053 times
Re: Print quality issue
Posted: Thu Apr 09, 2015 9:11 am
by zhangxueyou
240 degrees for extruder and 95 degree for bed are enough for ABS.
I think you'd better tighten the x belt a bit, not too much.
You'd better give me your slicer settings, give me some pictures, I think your slicer settings are not so good.
Please tell me your nozzle diameter.
Posted: Thu Apr 09, 2015 3:51 pm
by vad7
I think 240C for my plastic is not enough - small pellets formed and layers do not adhere good.
Nozzle: 0.3
Filament diameter 1.75, multiplier 0.6
Temperature first layer: 255, other: 250, bed 120.
- 5.jpg (212.53 KiB) Viewed 13049 times
- compare prints: new and yesterday
- 4.jpg (326.45 KiB) Viewed 13049 times
Posted: Thu Apr 09, 2015 4:03 pm
by zhangxueyou
You can try with my setting. Now that you think 260 degrees is better, then you can keep 250 degrees.
And from the first layer you print, I think you can lower the distance between hotend and hot bed to about 0.2mm.
Sorry, we have to keep approval system, because there will be more spams, which will spend us more them replying people who really need help. Please understand. When we are on duty, we will approval system once per minute, and we will reply you as fast as possible, unless the problem is really hard to solve that we have to assemble our technique support to get a best solution.
Posted: Thu Apr 09, 2015 5:11 pm
by vad7
My setting is based on your setting except speed (my lower) and temperature.
There is 1 sheet of paper between hotend and hot bed .
Why did this happen?
- 6.jpg (101.1 KiB) Viewed 13024 times
Posted: Fri Apr 10, 2015 9:55 am
by zhangxueyou
Could you please send me your stl files? I want to find out the problem with my experience. Thank you.
Posted: Fri Apr 10, 2015 2:22 pm
by vad7
Attached.
Posted: Fri Apr 10, 2015 3:11 pm
by zhangxueyou
Now I am printing with stl file, I think I should also print with g-code file with your settings. Please send me the g-code files.
Posted: Fri Apr 10, 2015 3:41 pm
by zhangxueyou
Posted: Fri Apr 10, 2015 3:50 pm
by zhangxueyou
I print with 240 degrees for extruder and 95 degrees for hotbed.
- QQ截图20150410154854.png (386.13 KiB) Viewed 13016 times
