Marlin firmware
Marlin firmware
I buy a geeetech prusa I3 pro B with ramp 1.4
Where can I find the marlin firmware preconfigure ?
zhangxueyou
Re: Marlin firmware
Please leave your email address , I will send the firmware to your email.
Re: Marlin firmware
Hi, I too bought the I3 pro B (one that prints 5 types of filament), I'd like to have the firmware also.zhangxueyou wrote:Please leave your email address , I will send the firmware to your email.
thanks
Re: Marlin firmware
Looks like I am having issues with the firmware you've supplied (prints were corrupting 2-3hrs into the print), I've downloaded the current version of Marlin and applied the i3 Pro B settings and have completed 2 long prints (3hrs+) successfully so far. Will keep testing with the new firmware (1.0.3).
Can someone please advise where I may set the 'home' location so that the extrusion head is sitting above the front left corner glass, and not the hex nut?
zhangxueyou
Re: Marlin firmware
Hi, Vicoz2009Vicoz2009 wrote:Looks like I am having issues with the firmware you've supplied (prints were corrupting 2-3hrs into the print), I've downloaded the current version of Marlin and applied the i3 Pro B settings and have completed 2 long prints (3hrs+) successfully so far. Will keep testing with the new firmware (1.0.3).
There are 2 mothods:
1. Rotate the srew above Z endstop clockwise to let the screw touch Z endstop earlier.
2. Lower the height of hot bed. I don't suggest this method, because this will spend you longer time. If the bed is not level, it may lead to a bad printing.
Re: Marlin firmware
My Z travel is fine, its actually the X and Y. I was hoping there is something in the firmware that I can change this. I saw somewhere it can be changed via GCODE but that would be temporary only.
zhangxueyou
Re: Marlin firmware
Sorry, the axis will stop as it touches endstop. Generally, the nozzle will be above the front-left corner of glass, not above the hex nut. If you really want the nozzle exactly above the front-left corner of glass, I suggest you re-design a x-motor holder to change the location of x endstop.Vicoz2009 wrote:My Z travel is fine, its actually the X and Y. I was hoping there is something in the firmware that I can change this. I saw somewhere it can be changed via GCODE but that would be temporary only.
The command you can give in g-code can be referred in "Marlin_main.cpp".
Re: Marlin firmware
thanks
thanks
vinokuryakov
Re: Marlin firmware
I got Geeetech I3 Pro 3D printer with Sanguinololu controller v. 1.3a. My Y and Z axis are working fine. X and Extruder do not work when controlled via LCD2004 panel. When X and Extruder motors are connected to Y port of the controller they work when changin Y position. Swapping driver modules did not help. Next step I would like to reload the firmware. Can you please prodive the link for it?
Thank you.
Jacob
Thank you.
Jacob
zhangxueyou
Re: Marlin firmware
Hello, to protect the extruder motor, it can not unless the temperature is more then 180 degrees.vinokuryakov wrote:I got Geeetech I3 Pro 3D printer with Sanguinololu controller v. 1.3a. My Y and Z axis are working fine. X and Extruder do not work when controlled via LCD2004 panel. When X and Extruder motors are connected to Y port of the controller they work when changin Y position. Swapping driver modules did not help. Next step I would like to reload the firmware. Can you please prodive the link for it?
Thank you.
Jacob
