I can't to load the filament
Quinche
Post by Quinche »
Hello, I can not load my printer filament, they know what is the procedure for loading the filament in the extruder? 1.75mm
zhangxueyou
Re: I can't to load the filament
Post by zhangxueyou »
Press the spring and plug the filament into the nozzle. If you find it's stuck in the middle, use your eyes to observe how far the filament deviate from the hole, then unplug the filament and bend it slightly and plug it again.
If you really can not plug the into the nozzle, trying with the method above. You can unload the fan and heat sink first, then you can see where the hole is clearly.
AaronClay
Post by AaronClay »
This is a fantastic resource with a wealth of information. Friday Night Funkin' is the game that will help you recoup lost energy after a long day at work if you enjoy playing games to remain awake.
