Iduino Yun shield does not recognize USB memory
pooki
Post by pooki »
I received an Iduino Yun shield and after some tinkering got it running with MEGA 2560.
When trying to install memory stick nothing happens, no /dev/sd?1 device generated
I have tried with different memory types without getting any further.
Please does anyone know how to solve the problem.
root@iduino:~# lsusb
Protocol spec without prior Class and Subclass spec at line 17397
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@iduino:~#
http://wiki.openwrt.org/doc/howto/usb.essentials
All the packages seem to be installed but usb memory
is not recognized..
Should i use draguino v2. 2.0.3 firmware
WBRGDS.
Pooki
zhangxueyou
Re: Iduino Yun shield does not recognize USB memory
Post by zhangxueyou »
You can refer to this page:
http://www.geeetech.com/wiki/index.php/ ... nt.2Fsd.3F
how to set iduino.png (80.5 KiB) Viewed 6087 times
