Page 1 of 3
Extruder motor not turning !
Posted: Fri Jun 12, 2015 10:56 am
by zuzumba123
Extruded motor not turning , the motor works I tested it in other area , but when I plug it in extruder after hits 200 temperature , still does not work ... I need help
do all how in
http://www.geeetech.com/forum/viewtopic ... 17&t=16485 . need firmware i think
Re: Extruder motor not turning !
Posted: Fri Jun 12, 2015 11:05 am
by zhangxueyou
Let's check if the extruder motor driver is fine.
Turn off the printer, swap extruder motor driver with x or y motor driver, turn on the printer , Move x and y to center, let the axes auto home, check if all the axes move fine.
Posted: Fri Jun 12, 2015 11:09 am
by zuzumba123
i check it and it is fine...
Posted: Fri Jun 12, 2015 11:14 am
by zhangxueyou
Let's check if it is firmware issue. What is your printer type and mainboard type? We will send the correct firmware to your email.
by zuzumba123
extruder motor driver is fine i check it!
Posted: Fri Jun 12, 2015 11:16 am
by zuzumba123
geeetech i3. GT2560. He writes that it is "Ultimaker"
Posted: Fri Jun 12, 2015 11:17 am
by zuzumba123
Posted: Fri Jun 12, 2015 11:30 am
by zuzumba123
how can install firmware (repetier host or )?
Posted: Fri Jun 12, 2015 11:35 am
by zhangxueyou
Posted: Fri Jun 12, 2015 11:52 am
by zuzumba123
i updated gt2560 but still not work
