Here you can share you great ideas about hardware innovation. Here you can enjoy more professional and specialized services, Here is a platform for you to make a difference!
Extruded motor not turning , the motor works I tested it in other area , but when I plug it in extruder after hits 200 temperature , still does not work ... I need help
Let's check if the extruder motor driver is fine.
Turn off the printer, swap extruder motor driver with x or y motor driver, turn on the printer , Move x and y to center, let the axes auto home, check if all the axes move fine.
