Extruder motor not turning !
zuzumba123
Post by zuzumba123 »
:evil: Extruded motor not turning , the motor works I tested it in other area , but when I plug it in extruder after hits 200 temperature , still does not work ... I need help
do all how in http://www.geeetech.com/forum/viewtopic ... 17&t=16485 . need firmware i think
zhangxueyou
Re: Extruder motor not turning !
Post by zhangxueyou »
Let's check if the extruder motor driver is fine.
Turn off the printer, swap extruder motor driver with x or y motor driver, turn on the printer , Move x and y to center, let the axes auto home, check if all the axes move fine.
zuzumba123
i check it and it is fine...
zhangxueyou
Let's check if it is firmware issue. What is your printer type and mainboard type? We will send the correct firmware to your email.
zuzumba123
extruder motor driver is fine i check it!
zuzumba123
geeetech i3. GT2560. He writes that it is "Ultimaker"
zuzumba123
zuzumba123
how can install firmware (repetier host or )?
zhangxueyou
You can refer to this page to upload the firmware:
zuzumba123
i updated gt2560 but still not work
