Extruder motor d'ont work, please help me!
Laluuh
Post by Laluuh »
Hi everyone,
I have a small problem, I received my printer this week, no problems during assembly, while the axes walk properly except the extruder motor ...
the Motor work (tested on the X axis)
In manual extrusion does not work ...
I tried several software but no change.
I print at 200 ° c so I do not see where is the problem ...
(Sorry i have a bad english)
zhangxueyou
Re: Extruder motor d'ont work, please help me!
Post by zhangxueyou »
Firstly, please check if the extruder motor driver(I think it's A4988) is bad: Swap the extruder motor driver with x motor driver. Then let all the axes auto home, check if x motor can move. If x motor can not move, we can conclude that the extruder motor driver is bad.
Laluuh
Post by Laluuh »
It is done, and the X motor works perfectly ..
zhangxueyou
Motor is fine, so as the driver.
Can you extrude the filament with your hand?
Laluuh
Post by Laluuh »
Yes filament runs perfectly when I do get off by hand
zhangxueyou
Do you have a multimeter? There a screw on motor driver, rotate the screw to increase the power of motor, the voltage between screw and GND is around 1V.
Laluuh
Post by Laluuh »
I can not make handling now, so if I understand, I connect my multimeter on the screw and on the motor GND pin and I turn until 1V?
zhangxueyou
This is one of the potential reasons, if the extruder motor can run without filament.
Laluuh
Post by Laluuh »
The motor does not work with or without filament, he turned once during handling firmware but nothing after.
zhangxueyou
You said the extruder motor worked before you upload the firmware, but time we sent you the firmware is a few hours ago.Please try to re-upload the firmware we sent you.
