err: mintemp
rrobertm
err: mintemp
Post by rrobertm »
I have a big problem with my printer. It shows next message: "Err: MINTEMP". What should I do, because I cannot set the bed or nozzle temperature manually? It doesn't store tempertature settings. The printer model is I3 pro B.
It doesn't print any job too! Nothing is heating up!
zhangxueyou
Re: err: mintemp
Post by zhangxueyou »
Hi, when LCD is displaying "ERROR MIN TEMP", you can heat up the extruder, please check if you have connected extruder thermistor to correct slot. Please take a photo, let me check for you.
rrobertm
Re: err: mintemp
Post by rrobertm »
rrobertm wrote:I have a big problem with my printer. It shows next message: "Err: MINTEMP". What should I do, because I cannot set the bed or nozzle temperature manually? It doesn't store tempertature settings. The printer model is I3 pro B.
zhangxueyou
Re: err: mintemp
Sorry, I left a word out.
When LCD is displaying "ERROR MIN TEMP", you can not heat up the extruder.
Please show me your wiring.
rrobertm
Re: err: mintemp
Post by rrobertm »
Fixed err:mintemp, but now I got another problem: the extruder motor is not working. I moved it on x axis motor connector and it works. After that I switced the small motor modules on the mainboard and the one mounted for the extruder motor is not working.
zhangxueyou
Re: err: mintemp
rrobertm wrote:Fixed err:mintemp, but now I got another problem: the extruder motor is not working. I moved it on x axis motor connector and it works. After that I switced the small motor modules on the mainboard and the one mounted for the extruder motor is not working.
Is the extruder moving with no filament?
Blisk
Re: err: mintemp
Post by Blisk »
When you fix somethng you should write how you did it, that's why forum is!
