https://onedrive.live.com/redir?resid=D ... ideo%2cmp4
I don't understand why this is happening, at the end of the video the head just slides and hits hard on the corner. I have to abort fast to not inflict more damage.
At first i thought it was because the end-stop trigger-pin might not slide up or down correct. Even if it felt/looked good to me, so I tried doing this:
- Tried to tight the spring, same problem.
- Tried to loose the spring, same problem.
- Tried to put 2 springs, same problem.
- Tried the put the blue pin-thingy at the bottom with 2 springs (to make more contact), this is what you see in the video above. aka same problem.
The pin moves without a problem up and down, so it doesn't get stuck or anything like that.
But as you can see in the video, the first part it just goes Up -> Moves -> Down -> Up -> .... and so on. In the last part it seems that it "Slides" down.
What am I doing wrong?
