How to fix Z-axis wobble?
mespilus
Post by mespilus »
I'm not sure if my rods came slightly bent, or if the milling on the couplers isn't quite centered, but I am getting a wobble on the extruder head of about +/- 1mm from side to side when the Z-axis motors are moving the extruder head up or down. Has anyone else encountered this? How did you correct the problem?
Sherry
Re: How to fix Z-axis wobble?
Post by Sherry »
please tell me your printer type.thx
mespilus
Post by mespilus »
Acrylic I3 Pro B
Sherry
Post by Sherry »
mespilus wrote:I'm not sure if my rods came slightly bent, or if the milling on the couplers isn't quite centered, but I am getting a wobble on the extruder head of about +/- 1mm from side to side when the Z-axis motors are moving the extruder head up or down. Has anyone else encountered this? How did you correct the problem?
SORRY, which part do you said.could you take some picture and let me see.
mespilus
Post by mespilus »
It's the 8mm x 300mm threaded rods (vertical rods). One side wobbles a lot more than the other side. I'm pretty certain that it's the rods that are bent, and not a problem with the couplers.
mespilus
Post by mespilus »
The parts that are bent are the M8*L300mm Z-axis threaded rod (part #4 in the part list).
Sherry
Post by Sherry »
hi,mespilus.please find a reference plane,and press the threaded rod with rubber on the reference plane.Remeber not use the solid object and not destroy the thread.if it doesn't work,you need to change a new threaded road.thx
