print not sticking on heat bed
shiva
Post by shiva »
1. My print not sticking on heat bed.please let me know what is the gape between extruder nozzle
and heat bed ? where i set the gape ?
2. How to find Nozzle Diameter?
3. I put heat bed and Boro silicate glass together clip with 4 corner.But when the extruder come to
home axis, it removes clip and it get struck on clip and make large noise. Then if i remove clip it
will continue. So please let me know How to attach heat bed and Borosilicate glass?
Sherry
Re: print not sticking on heat bed
Post by Sherry »
hi,shiva.could you tell me your printer type.
and does the extruder hit the corner of hot bed when homing?if that,it doesn't matter with clip.
shiva
Post by shiva »
My printer is Geeetech Dual Extruder Prusa i3 Kit
Extruder hit Dovetail clamp and it gets struck on that.
Please send me stl file " Floating magnetic ring" which is in your Geeetech Dual Extruder Prusa i3 Kit Video add.
Sherry
Post by Sherry »
shiva wrote:My printer is Geeetech Dual Extruder Prusa i3 Kit
i'm regret that i could not send the stl files to you since the vedio was posted by one of our customer.if you would like the stl file ,you can try to contact him.thx
shiva
Post by shiva »
Ok no problem,i will create it.Clear my other doubts.
3. I put heat bed and Boro silicate glass together Dovetail clamp with 4 corner.But when the extruder come to
home axis, it removes clamp or it get struck on clamp and make large noise. Then if i remove clamp it
Sherry
Post by Sherry »
the best distance is an A4 paper,if you could take the paper back and forth,and there is a little obstruction,it's the best diatance.
regarding to the nozzle diameter,could you tell me your nozzle type .or you could find the information on our website.
regarding to the clips of 4 corner,maybe the axis could not could not hit endstops.please check the wire connection to endstops.it does'n matter with clips.
shiva
Post by shiva »
When i order i mentioned 0.4 mm Nozzle,but how to find that that is 0.4mm.
Sherry
Post by Sherry »
shiva wrote:When i order i mentioned 0.4 mm Nozzle,but how to find that that is 0.4mm.
you can see it on the nozzle.some words are engraved on its surface.
shiva
Post by shiva »
I put A4 paper and adjust bed to extruder on all 4corner,But still both extruder print
not sticking to bed.all filament moving with extruder.
Sherry
Post by Sherry »
shiva wrote:I put A4 paper and adjust bed to extruder on all 4corner,But still both extruder print
maybe there is jam in the nozzle,please clean it up.
and please wipe the glue on the hotbed.
