I am using it together with an Arduino One official board, I am powering the Shield through 9Vdc Vin pin, and the LEDs, and my main Workstation uses linux, therefore I have available nice network debugging tools. I can join the iDuino in the local Address 192.168.240.1, and change the parameters, but I can not go further.
First of all, I would like to update the Firmware. Is there any Geeetech official firmware, or do we have to install the official Dragino Firmware located in https://github.com/dragino/openwrt-yun ?
The firmware version in my iDuino is the following:
Code: Select all
Firmware Version: Iduino-V1 geeetech-2.0.2
Build Time: Wed Jan 14 17:10:01 CST 2015 My second question is related to the fact that I can not join the iduino board to my local network, after a long reset (>30sc) I can go to the iDuino Web page and change the parameters, but then when I start the board It never joins, and i is not visible in my local network.
I am trying now using the Ethernet port, but . Is there anything else I need to do, that it is not explained in the Geeetech and Arduino wiki?
Thank you in advanced!
