home problem
mga
home problem
Post by mga »
When I press home Repetier host: the engine reaches its maximum Y and trembles, even X reaches the limit but does not tremble, while Z does not reach its limit. It does not seem fair. I ask for suggestions to solve this. I think they need to reach the top and then go down after reaching the endstop.
Re: home problem
Do you have a video about this? and what's the printer type?
mga
Re: home problem
Post by mga »
I send you the video, but I had to compress it into zip because the system would not let me send mp4 files.
start.zip
(3.27 MiB) Downloaded 574 times
Re: home problem
The Y axis endstop might be open circuit or connected wrong, so the motor keeps hitting the endstop and won't stop I think.
mga
Re: home problem
Post by mga »
With the support I have solved this problem. I hope soon to be able to configure everything. Unfortunately I have to replace an engine.
mga
upgrade...
Post by mga »
I must not deny what I said before.He has started to not work without intervention. I begin to believe that they'll never see the print. How do home? How is it that the endstop no longer work?
mga
Re: home problem
Post by mga »
for a small fraction of time it had started to operate.He continues to see endstop and recognize the state triggered or open, but does not issue the correct instructions and engines continue to push despite the endstop reached by screws.
Re: home problem
When you home your printer, did you put the probe up?
mga
Re: home problem
Post by mga »
It of course, but nothing changes is that the probe is lowered, whether it is raised. When I press home the engines raise uninterrupted carts and I have to turn off.
Sherry
Re: home problem
Post by Sherry »
hi,maga.do the y still hit the endstop constantly.i do a test,if i connect y endstop cable to x connector on mainbaord.the y will hit endstop constably without stop.please see if the endstop cables connection are correct.
