Malfunction Prusa I3 x --
RobertoZampatti
Post by RobertoZampatti »
I just installed the 3d Geeetech Prusa I3 X printer and turned on, the screen turns on, but does not display any data on the screen.
Nor engines move.
The cables connecting the screen with the board, they are connected correctly.
I request inform me the problem with this fault.
Thank you.
Hola.
Acabo de instalar la impresora 3d Geetech prusa I3 X y al encenderla, se prende la pantalla, pero no muestra ningun dato en la pantalla.
Tampoco se mueven los motores.
Los cables que conectan la pantalla con la placa, estan conectados en forma correcta.
Les solicito me informen el problema de esta falla.
Gracias.
Re: Malfunction Prusa I3 x --
dogma
Post by dogma »
Mine did the same. I changed the sd and the LCD cable (opposite what the instruction shows) and it started working.
