Printing Problem where the Z-axis moves
rmrodrigues
Post by rmrodrigues »
Hi there,
I have a printing problem where the Z-axis moves.
Please see the attached photo.
Someone can help me solving this problem.
Thanks.
Best,
RMRodrigues.
Re: Printing Problem where the Z-axis moves
what's your printer type? maybe your Z axis is not well assembled, and wobbing all the time..
rmrodrigues
Hi Mark,
Thank you for the reply.
My printer is a Pro C. I think it's well assembled.
Thanks.
RMRodrigues.
So maybe your slic3r settings are not that good, you can check the settings here for my G2S pro, see if it can help you.
I use repetier host1.5.6 with the default slic3r.
G2S pro 1.5.6 config.zip
(1.67 KiB) Downloaded 621 times
rmrodrigues
Hi Mark,
Thank you.
I've a Mac. I'm using the 0.56 version. Is it ok?
Cheers,
RMRodrigues.
Nope, you need to open it in windows.
rmrodrigues
HI,
I tried that config and the problem remains. It seems to be a z axis problem.
since you said your Z axis is well assembled, so I think maybe you can check this link here:
https://www.simplify3d.com/support/prin ... eshooting/
rmrodrigues
My printer has some wobbling. It has the same behaviour shown on this video: https://www.youtube.com/watch?v=aBcGf69i9RI.
How I can fix it?
Cheers,
RMRodrigues.
your rods, before you assembled them, do they bended or not? If so, maybe you need to make them straight.
