I figured out that the axis move like this:
Is that how it's supposed to be? I'm confused because the end-stops for y and z are at the minimum posititons, but for x it's at the maximum position (left).
Also: Is there a way to make an axis move beyond the home position? I set the home-position somewhere and now I can't get the z axis to move down anymore. just up and down the little bit from where home was set. Do I have to screw it all the way down manually or can I somehow force it to go beyond it's limit?
Thank you very much for your help!
