I have all but finished building my G2s Pro, but a couple of things seem unclear.
The spots for the SD Card slot and LCD slot are obvious, but what is not obvious is which one goes in which connector. They are both the same and it is identified on the PSB, but not on the back of the LDC/SD Card Panel, so I don't know which one is which and do not want to connect until I know.
Second issue is the limit switch on the Hot End. It does not seem clear in the instructions where that is supposed to be connected on the PCB. I ahve the Xmax, Ymax and Zmax in place, but where does the Hotend min one go?
One for Geeetech for info back. The switches on the X, Y, Z were all a bit short on my printer, and I had to extend them to make them fit.
Hope to get some info back soon, so I can finish the build and commence the programming etc
Kyle
G2S Pro Construction questions
Re: G2S Pro Construction questions
The LCD cable, you can interchange them if they are wrongly connected, check out this link:
http://www.geeetech.com/forum/viewtopic ... 23&t=17040
And the probe endstop, plug it in the Z Min socket.
Awesome. Thanks so much for a fantastically quick answer
