Have finally had some decent success with the M201. I switched over to S3D and used the Wanhao Duplicator I3 profile - good stuff with little to no tweaking. One thing that seems to be a problem with S3D is that it is not allowing me to control mixing at all via templates. Any suggestions on what you guys are sending in Repetier Host to get the mixing to work? Is it a special GCODE? ETE/ETA times are not displaying either. Other than that, all the commands worked great on the print with no errors.
Thanks,
M201, Simplify 3d and Mixing Colors
ravynsage@hotmail.com
Re: M201, Simplify 3d and Mixing Colors
no Gcode command for this mixing function, it's the codes, but I don't know how it works either.
