No LCD display
ZOAB
No LCD display
Post by ZOAB »
Hi everyone,
After building my 2gs pro delta printer I saw info on the display.
Then i tried to install firmware (configuration.h) with arduino.
Then only 2 lines of blocks appear on the green display. No more info. No movements with repetier.
What can be wrong? Surprisingly the configuration.h file was only 642 bytes. Can this be the problem ?
Thanks!
Boaz
Re: No LCD display
you need to install all the files under the firmware folder, not just the configuration.h one, check out this link to download and install the firmware:
