There is too much friction in the hole/metal piece the pin slides in. Getting the pin in was hard - seems it was thicker at one end.
So probing works in the middle, but when moving to the edges it gets stick resulting in motor overload and having to do an emergency abort - not good
Is the mechanism normally this bad or was the parts I got just out of specs (possibly because they are painted in this silver type paint.
The pin should move absolutely parallel up and down with almost no friction. I did add a drop of oil to help it along, but to no avail.
Order #20160305143654686
Also I got M5x16 screws instead of M4x16 screws in bag #25
Thanks,
Finn
