extruder does not work in the Play mode
Bennyfly
Post by Bennyfly »
I have a DELTA G2S (metal)
My problem is ... extruder does not work in the Play mode.
Hardware is ok. Operating in manual mode with the extruder 1 and 2 is also ok. (forwards and backwards)
Already have different firmware but always made without success.
What else can I do ?
Re: extruder does not work in the Play mode
"Already have different firmware but always made without success."
Do you have any details? what the specific problem is?
Bennyfly
Post by Bennyfly »
Have found errors.
The code (G1 e2.5 F 2500) go into the Manual Mode. bad will not run in the Play Mode. This is clearly a firmware error.
The software (RKMA_GT2560_G2) is working properly.
The rotation of the encoder button is also wrong.
Plus in the left turn ???
Udo
did you use the correct firmware? the latest one is here, and remember to choose correcponding one:
