min temp error
kevink18
min temp error
Post by kevink18 »
I just got my GS2pro put together installed firmware and when I try to connect is shuts down for min temp error. All temps are showing 0 deg tested board by shorting out pins to test for max temp like in another post they still read 0 deg. could this be a firmware issue or a bad board
Re: min temp error
Is there a bad soldering between those pins of the thermistor connectors? Or did you try to reinstall the firmware?
