Always getting an error when trying to upload my firmware
SLCPUNK
Post by SLCPUNK »
Hey guys,
I followed the steps on this thread to the letter: http://www.geeetech.com/forum/viewtopic ... 20&t=16433
Unfortunately every time I attempt to upload the Configuration.h file in order to reverse the direction on my x and y axis I get the following error:
exit status 1
#error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
First off I don't see 'Sanguino' in the 'Tools -> Boards' menu even after I installed every board library there is. Second, I've tried selecting the Mega2560 and MegaADK, and I still get the same error.
I have the Geeetech Prusia i3 Aluminum. It's a great little machine from the looks of it but so far all I've been able to do is manually control the axis. Any help would be appreciated.
Admin
Re: Always getting an error when trying to upload my firmwar
Post by Admin »
1Did you disconnect the board to the repetier host?
2You can try to reflash all the files not just the congig.h.
3 Choose correct board type.(Tools>Board>Sanguino W/ATmega1284p 16mhz)
