Please help "Error maxtemp"
FLeeX
Post by FLeeX »
Hello guys!
I have a problem! When I printing something and when it's about 10% already printed comes this error " Err Maxtemp" :( Before the temperature starting to jump from like 240 to 215 or to 265, temperature is set to 240 because I'm printing with ABS.
Do you have any ideas?
Thanx a lot in advance.
Toy
Re: Please help "Error maxtemp"
Post by Toy »
I think you need to check the thermistor, see if there's a short, or the max temperature you set in firmware is not right, please check the post:
http://www.geeetech.com/forum/viewtopic ... 23&t=17030
If the thermistor is right, you can refalsh the firmware.
FLeeX
Post by FLeeX »
Thanx a lot for the info, may be I will need it in future :) but now it prints really good, I think it was a problem with printing with ABS at high temperatures, I tried to print at 245C and this error came up but now I'm printing at 230-240C all is ok. May be it was because at printer settings in Repetier I put 230C as a "Default Extruder Temperature" and 70C as "Default Heated Bed Temperature" So I think it was my fault or I'm wrong?!
Toy
Post by Toy »
Maybe the max temp in firmware is a little low, so when you set the heat temperature at a high value, it will reach the max temp easily and get the error.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define BED_MAXTEMP 150
