moving from pla to abs
tassat01
Post by tassat01 »
Hi there,
After a few weeks of testing my printer and being very impressed with how it prints I've got a roll of abs to play with.
As i found pla great testing is there any special settings I needed to change.
In pla I use the blue tape but I understand you need to heat the bed. Do you print directly onto the glass and what's a recommended temperature for abs and the hot bed.
Pete
Re: moving from pla to abs
tassat01 wrote:Hi there,
Pete
Hi,Pete
For ABS filament,the recommended temp is 230-240℃ for extruder,90-110℃ for heat bed.
tassat01
Post by tassat01 »
when printing in abs i notice that when its doing the lap around before printing its not a straight flow but goes on the glass with a serated edge like.
tassat01 wrote:when printing in abs i notice that when its doing the lap around before printing its not a straight flow but goes on the glass with a serated edge like.
More details would be appreciated.
Regards
syossi2
Post by syossi2 »
Pla after abs:
From my experience when i move from abs to pla. I always set the temp to 240c for few minute let the pla flow down few second until i see that all come freely then i down the temp to regular pla around 200
Abs after pla:
no problem.....
printing 3D with M201 Geeetech
tassat01
Post by tassat01 »
I'll post some photos when I'm home from work
tassat01
Post by tassat01 »
after getting some other issues fixed and realising when it was extruding the filament i realised that it was too far away from the bed on the first layer. this happened also in pla too.
I relised that i had to reload the configuration file back into repetier and realised theres one for pla and abs. Next time ill load the config for abs and try it out.
I changed back to pla and got a blocked extruder but that was pretty easy to unblock.
